查看:6564 回复:2
爱音不停
杰夫乐林Jeffrowland Continuum 250W 合并功放
 机器朋友一有自用,无修无任何问题,250W推力很好,音色不错,喜欢的网上介绍很多,机器原包装也在。
Specs: 250 Version / 500 Version
Output Power, Continuous RMS watts, both channels driven
250 watts @ 8 ohms / 500 watts @ 8 ohms per channel /
500 watts @ 8 ohms / 1000 watts @ 4 ohms per channel
Frequency Response
5 Hz – 60 kHz, -3 dB @ 8 ohms / 5 Hz – 45 kHz, -3 dB @ 8 ohms
Peak Output Current
35 amps / 40 amps
Dynamic Range
117 dBa / 120 dBa
Load Impedance Range
3 ohms – 16 ohms
Input Impedance
48 k ohms
THD and Noise, 0.1 watts to Maximum Output
< 0.05%, Typically .006% @ 1kHz / < 0.1%, Typically .01% @ 1 kHz
Damping Factor @ 1 kHz
> 1000 / > 1000
Gain Structure
Preamplifier Section 14 dB, Amplifier Section 26 dB
Volume Control Range
99.5 dB
Volume Control Resolution
0.5 dB +/- 0.05 dB Over Entire Range
Common Mode Rejection Ratio
> 85 dB, 20 Hz to 20 kHz
Inputs
2 pair Balanced (XLR), 2 pair Unbalanced (RCA)
1 pair Unbalanced (RCA), Unity Gain (Bypass)
Outputs
1 pair Balanced (XLR), 1 pair Unbalanced (RCA)
1 pair CE-Approved Speaker Wire Clamp
Power Consumption
Idle – 25 watts, Max – 1000 watts / Idle – 35 watts, Max – 2000 watts
Power Supply
Switch Mode (SMPS) / Switch Mode (SMPS) with active power factor correction (PFC) and universal AC input voltage
Amplifier Weight
41 lbs. - 18.6 kg / 44 lbs. - 20 kg
Overall Amplifier Dimensions (H) x (W) x (D)
5.3" x 15.5” x 15.0” (135mm x 394mm x 380mm)
Because Jeff Rowland Design Group is constantly analyzing new design improvements, we reserve the right to change or modify product specifications without notice or obligation.
多。
产品名称:杰夫乐林Jeffrowland Continuum
品牌:杰夫乐林Jeffrowland
型号:Continuum 250W
成色:二手95
价格:29000
损伤情况:很小的划痕
保修期:过保
运输方式及运费:200
爱音不停
  Re:杰夫乐林Jeffrowland Continuum 250W 合并功放
 HIFI吧,
爱音不停
 机已出
