查看:3181 回复:0
汕头金亮音响
二手 原产英国贵族 RESPONSE D MONITOR中置
 Following the successful release of the ProAc Response D range we have designed and built a new high end studio monitor The new Response D Monitor is a radical new design delivering greater bandwidth, higher sensitivity with dynamic, yet smooth and open performance, and are available with dome or ribbon tweeters.
At the hub of the new Response D Monitor speaker is a special shielded version of the bass driver found in the D28 and the D38. This unit is a bespoke ProAc driver built to studio quality specifications. These exciting new drivers offer lower resonance, which means the cabinet dimensions can be decreased slightly.
The cabinet is very rigid and heavily damped and the new bass drivers are loaded by a front equalised reflex port.   These superb new drivers are linked seamlessly through a refined HQ crossover network. The overall result is a monitor which can handle anything with high sensitivity, superb dynamics and the usual ProAc natural sound.
It is capable of fitting in any  system where high output and accuracy are high in demand. These monitors are available singularly or in pairs and in a range of real wood veneers the Response D Monitor is available for demonstration through your nearest ProAc dealer.
Nominal Impedance
4 ohms
Recommended Amplifiers
20 to 300 watts
Frequency Response
25hz to 30Khz
Sensitivity
90db linear for 1 watt at 1 metre
Bass/Midrange(2)
61⁄2” (165mm) ProAc unit with special coil and shielded magnetic system.
Tweeter
1” (25mm) soft silk dome with air cooling.
Crossover
Super HQ PCB with finest components and multi strand cable.
Dimensions
93⁄4” (250mm) high
26” (660mm) wide
113⁄4” (300mm) deep
Weight
55lbs (25kgs)
Mode
TV/Stand mounted
Grille
Acoustically transparent crimplene
FinishAvailable in the following real wood veneers: Black Ash, Cherry, Maple and Mahogany. Ebony and Birds Eye Maple to special order.
* Due to our policy of continuous improvement specifications are subject to change without notice.
产品名称:贵族 RESPONSE D MONITOR
品牌:贵族
型号:RESPONSE D MONITOR
成色:二手95新
价格:9800
损伤情况:网罩有细微老化
运输方式及运费:淘宝交易/德邦货到付款/自提
