查看:5032 回复:2
Stjldq
现货 法国 Metronome/文豪 CD8 签名版CD机 播放机 全新正品保修
 法国 Metronome/文豪 CD8 签名版CD机 播放机 [全新正品保修]
淘宝链接:https://item.taobao.com/item.htm?spm=a1z10.1-c.w4004-10211600418.33.HYmBfj&id=549751584676
Metronome Technologie (文豪) CD8 Signature CD播放器,?用祛?必?的???芯 Philips CDM12 PRO2 V6.8 拾?系靳,置於?篦的正中心位置,取得最平均的承托力及避震效果,??起拾?系靳的大面峰平台檫始,再到其三?式 (前二後一) 架?的三分文治式?挂系靳,再落到?箱底下,拾?系靳得到平均的三?式承托,置震得以更平均?走。呃肺韵?睫?是一大咄步。CD8 Signature CD播放器用料嘱究,?噪比高哌120dB和24bit/192kHz腽晶片解瘁?路,技戌成熟,咦?O其?定又精?。?置推慎式韵?,免除托毙或吸入式蒉多的活?酵件,大大提升整篦可靠性及耐用程度。????唱片的??萦亦用上咝蟹??煽康母??圆荤n?萦,再配合自行研办费?塑?的Delrin (聚甲醛) 所氧成的高?性高?定的唱片?,有效提升唱片旋弈?定性,拾?的?催性。此外,接地功夫亦做到足,??路到光?酵件,甚至CD上的祜?亦一?通咿地??走,?少整篦??性干?。?妥善屏蔽?磁波干?/射铎干?(EMI/RFI) 的?型??器,一共三?,劫合多酵各自?立的?源??,分?供?斤CD伺服?路、?字?路、模??路。免除相互干?及塍?污染,提高?噪比,使音?背景更加?祜,提高整篦的分析能力。
Technical specifications
•Pick up mechanism:
Philips CDM12 PRO 2 v 6.8 with METRONOME TECHNOLGIE
proprietary modifications and new Delrin clamp .
•DAC Resolution:
Dual 24 bit/192 kHz bitstream technology allowing 120dB of
signal to noise ratio at the converter.
•Analog stage line:
Frequency bandwidth: 10Hz - 25 kHz +/- 0,1dB
Analog stage line based on a JAN6922 couple chosen for its
amazing audio quality.
•Digital Input:
USB asynchronous type B allowing direct connection with a
computer (PC and Mac) and accepting high resolution signals
such as HD_Master (24bit/192kHz).
•Digital Output:
S/PDIF 75 Ohms RCA connector 16bit/44.1kHz
•Analog Outputs:
Unbalanced 2.5V RMS @0dB - 47K Ohms- RCA connectors
Balanced 2.5V RMS @0dB - 600 Ohms- XLR connectors
•Power supply:
EMI rejection by Schaffner filters. 3 main high quality toroidal
transformers and 7 separate and independent regulation lines.
•Accessories:
Remote control with Top side built in aluminum.
One set of Delrin cones ( 3 units magnetizable ).
•Voltage:100 V or 120/240 V - 50/60 Hz
•Power consumption:50VA
•Dimensions (WxHxD):450 x 115 x 435 mm
•Weight:15 kg
•Colour :Full silver or full black
产品名称:Metronome/文豪
品牌:Metronome/文豪
型号:CD8 签名版CD机
成色:全新全新正品保修
价格:35800.00
保修期:全新正品保修
运输方式及运费:双方约定
Stjldq
  Re:现货 法国 Metronome/文豪 CD8 签名版CD机 播放机 全新正品保修
Stjldq
 2
