查看:5212 回复:5
Stjldq
现货 挪威 音乐之旅 ECI-6D 合并功放 加解码一体机 全新正品保修
 挪威 音乐之旅 ECI-6D 合并功放 加解码一体机 [全新正品保修]
淘宝链接:https://item.taobao.com/item.htm?spm=a1z10.5-c.w4002-8024622216.16.5iqkFD&id=43468203283
Electrocompaniet这次一共推出ECI 6D与ECI 6DS两种版本,前者的「D」代表内建数类转换线路,後者的「DS」则除了内建数类转换线路之外,还具备Wi-Fi与uPnP网路串流播放功能。
ECI 6D
Fully balanced integrated amplifier with built-in D/A converter
The ECI 6D is a powerful integrated amplifier, equipped with a number of analogue and digital inputs offering  a wide range of connectivity.
With its high performance sample rate converter and D/A converter the ECI 6D is able to improve all of your digital sources like TV’s, cable- and satellite tuners, CD/DVD/Blu-Ray players and not to forget your computer and media player. Independent of their native resolution all digital sources will be upsampled to 24bit/ 192kHz and can be connected by SPDIF, USB or Toslink.
The new ECI 6D offers 2 x 125 Watts and is based on the successful ECI 5 MK II. To make it even better we have equipped with an even better power supply and a more sophisticated preamplifier module. As a result we can offer you an extremely substantial and dynamic amplifier, capable to control a wide range of speakers in the marked.
Analogue sources can be connected to one balanced (XLR) input and three single-ended (RCA) inputs. Two preamplifier outputs, one balanced and one single ended, making sure the amplifier is prepared for future extensions.
All measurements are made at 120V / 240V  //50Hz / 60Hz
 Digital section:
D/A converter24 bit/192 kHz
Sample rate converter24bit / 192kHz
InputsSPDIF, 2x Toslink, 1x USB
USB:                                    asynchronous  up to 24bit/ 192kHz supported
SPDIF:                                24bit/ 192kHz
Toslink:                              24bit/ 96kHz
Preamplifier section
Input impedance ( Balanced input )47Kohm
Maximum input level10 Volt RMS
Noise floor ( 1Vrms, 20 - 20 kHz, balanced)
-135 dB
THD + N   (1Vrms, 20 - 20 kHz, balanced)    <0.004%
Gain (Balanced)0 dB
Amplifier section
Output Impedance< 0,02 Ohm
Frequency response1 – 150 kHz
Channel separation> 120 dB
THD ( 20 - 20 kHz)< 0.004%
Maximum peak current>100A
Damping factor  8 ohm load>350
I Input sensitivity  120W output1.3Vrms
Input sensitivity HT  120W output1Vrms
Gain HT Inputx36 (31 dB)
Rated output power
8 ohms2 x 125 W
4 ohms2 x 200 W
2 ohms2 x 370 W
Power consumption
110 W
Standby1W
(no load or signal)
Dimensions
Width465 mm / 18.3 inches
Depth405 mm / 16 inches
Height128 mm / 5 inches
Weight20Kg / 44 lbs.
产品名称:音乐之旅/ELECTROCOMPANIE
品牌:音乐之旅/ELECTROCOMPANIE
型号:ECI-6D
成色:全新全新正品保修
价格:17000.00
损伤情况:全新正品保修
保修期:全新正品保修
运输方式及运费:双方约定
Stjldq
  Re:现货 挪威 音乐之旅 ECI-6D 合并功放 加解码一体机 全新正品保修
Stjldq
 2
Stjldq
 3
Stjldq
 现货 现货 现货
Stjldq
 诚信为本 信誉第一 精益求精 至诚服务
